FlexCAN Reset Stuck
FlexCAN Reset Stuck
1,571件の閲覧回数
brycer
I am having a problem with the FlexCAN module on our MIMXRT1060-EVK evaluation board. When using the MCUXpresso IDE with the board's SDK and C, after creating a project and setting up the CAN peripheral and routing the pins (See below for configuration screenshots) the program that is created runs and compiles but it gets stuck in the "Wait until FlexCAN reset completes" loop of the fsl_flexcan.c file (See code snippet below).
Thank you all!
/* Assert Soft Reset Signal. */
base->MCR |= CAN_MCR_SOFTRST_MASK;
/* Wait until FlexCAN reset completes. */
while (0U != (base->MCR & CAN_MCR_SOFTRST_MASK))
タグ(2)
3 返答(返信)
1,388件の閲覧回数
kerryzhou
Hi Bryce Readyhough ,
  I have a question, do you test the official SDK code which is located in this folder:
 SDK_2.6.2_EVK-MIMXRT1060\boards\evkmimxrt1060\driver_examples\flexcan\
 I run the flexcan_interrupt project, and even didn't connect the other CAN node, I didn't stop at the reset point which ou have mentioned:
So, I think you can test the official SDK project at first, if the SDK project works, then we can check more detail in your own created project.
Kerry
1,388件の閲覧回数
brycer
I just ran the official SDK project and it ran with no issue.
1,388件の閲覧回数
kerryzhou
Hi Bryce Readyhough,
  Before you do the CAN operation, please add this code , then test it again on your side:
CLOCK_EnableClock(kCLOCK_Lpuart1);
  Do you still have the problems?
  If your own project still have problems, I think you can copy the official code to your own project, and test it again.
Wish it helps you!
Any updated information, just let me know.
Kerry
