Hello everyone,
I download the DeepViewRT SDK(RT1170+eIQ) from this link ( https://www.nxp.com/design/software/development-software/eiq-ml-development-environment/eiq-inferenc...) and I installed it by drag & drop the zip into "installed SDKs" , and I can run the model runner sample without problems
And I also download and install the standard sdk (2 .9.1 / 2.9.2/ 2.10.0) from https://mcuxpresso.nxp.com/en/welcome
When I run the sample project modelrunner (for example 2.9.2) , I find that error happens like follows
If without the deepview SDK (SDK_2.x board_MIMXRT1170-EVK) , the sample project can build well.
if with the deepview SDK (SDK_2.x board_MIMXRT1170-EVK) ,the error will occur
Although I can fix it by rename the defined eiq interrupt....
Do we need to call uesrs' attention to this problem?
ZHOU
已解决! 转到解答。
Hi Zhou,
The DeepViewRT library included with the SDK is specific to the eIQ Portal version. So they need to be kept in sync. There's not a way to fix that other than using the latest SDK and latest version of eIQ Portal. I'll have the web team take those links down on the website to avoid future confusion.
-Anthony
Thanks for your reply.
1) DO you know the reason why the former version of standard SDK(2.9,1/2,9.2) can not work well with DeepViewRT SDK(RT1170+eIQ)?
-- Sorry, I don't know and you may need to contact the SDK team to explain the reason.
Have a great day.
TIC
Hello, jeremyzhou
Thanks for your confirmation. I also check that The new standard SDK(2.10.0) works well with the deepview SDK (SDK_2.x board_MItellMXRT1170-EVK).
I will tell customers to update SDK to the new SDK(2.10.0).
ZHOU
I try it just a moment ago, the issue won't raise when the SDK_2.x_MIMXRT1170-EVK is updated to 2.10.0.
TIC
HI jeremezhou
in other word,Compared with former version ,what kind of modification of standard SDK(2.10.0) makes the error disappear?
ZHOU
Hi Zhou,
-Anthony
