Debug bootloader & application images using JLink
1,007件の閲覧回数
thivya_ashokkum
I'm trying to debug my bootloader, application and recovery images using JLink. I found a document "Debugging Bootloader and Application using KDS" and followed the steps. However, the "Commands" option where they add the symbol file for the application is missing in my Debug Configuration. I'm using MCUXpresso 11.0.1. Where should I be adding the symbol file instead?
I'm attaching a screenshot of my Debug Configuration edit window where the "Commands" option mentioned in the document is missing.pastedImage_1.png
タグ(1)
952件の閲覧回数
FelipeGarcia
I recommend you to check MCUXpresso IDE User Guide, in chapter 11.3.4 you will find how to add symbolic information from additional projects via the Other Symbols tab on a projects launch configuration.
Hope it helps!
Felipe
- We are following threads for 7 weeks after the last post, later replies are ignored.
- Please open a new thread and refer to the closed one, if you have a related question at a later point in time.
