08-21-2022
08:07 PM
887 次查看
antoniohsu888
I use mp3 with sampling rate 32k Hz and bit depths 32 bits to test the maestro mp3 deocde.
It will decode the mp3 to sampling rate 32k Hz and bit depths 16 bits.
Is it possible force it to decode the bit depths to 32 bits ?
已解决! 转到解答。
08-21-2022
10:56 PM
883 次查看
From the maestro lib description, the mp3 decode just support 16 bits, not 32bits.
So, to the 32bit depth mp3, maybe you need to switch it to the 16depth at first.
Wish it helps you!
kerry
08-21-2022
10:56 PM
884 次查看
Wish it helps you!
kerry
