yocto engineering problem
xueyf
hello
     When I pulled the yocto project from https://github.com/nxp-imx/meta-nxp-desktop/tree/lf-6.1.1-1.0.0-langdale,An issue occurred after compiling with the bitbake imx-image-desktop command:
The host I used was ubuntu18.04,How to solve this problem
Harvey021
Hi @xueyf
To check the error log, log.do_compile might find details to help fix the do_compile error.
Have you followed the IMX_YOCTO_PROJECT_USERS_GUIDE_LF6.1.1_1.0.0.pdf for host package? and the recommended minimum Ubuntu version is 20.04 or later.
You will find Yocto user guide from the link: L6.1.1_1.0.0_LINUX_DOCS (nxp.com)
Harvey
