which u-boot version supports for imx6dl board
1,220件の閲覧回数
saida
hi i.mx community
can any one tell me which version of u-boot supports for i.mx6dl board
and depending upon this board i am making my custom board for that also send detailed procedure to modify uboot for my board
thanks in advance
happy weekend
タグ(2)
6 返答(返信)
977件の閲覧回数
igorpadykov
Hi saida
uboot version can be found in i.MX_Linux_Release_Notes.pdf
included in documents L3.14.28_1.0.0_LINUX_DOCS
For modifications one can look at i.MX_6_BSP_Porting_Guide.pdf
977件の閲覧回数
saida
thank you for your reply
i gone through that document which shows that u-boot-2014.04 is supporting version
i downloaded source code and i have done following steps
$ tar xzf u-boot-2014.04.tar.bz
$ cd u-boot
$ make mx6dlsabresd_config (it was showing some nitrogenxl and config for mx6dlsabresd board)
generated u-boot.imx file than
$ dd if=u-boot.imx of=/dev/sdc1 bs=1k seek=1
$sync
i inserted in sdcard slot but its unable to boot
please help in this regard
thank you
977件の閲覧回数
ThomasG1z
I assume you don't want to dd to partition 1 on sdc disk, but /dev/sdc itself, or the offset will be wrong. And if you also have the rootfs on this disk make sure you have enough space for u-boot (and perhaps the environment depending on where you store that) before the rootfs partition starts (e.g. sdc1), start at e.g. 16MiB offset for that.
977件の閲覧回数
saida
thank you  for reply
when i insert sdcard through usb adapter in /dev/ there are  two partions its showing sdc,sdc1 may be i selected wrong one(that is sdc1)
can you give the details of how sdcard should be formated and why the offset is at 1024 bytes address
thank you
977件の閲覧回数
ThomasG1z
sdc is not a partition but the raw disk. The offset is because the partition table will start from 0, so u-boot need to reside after that.
I'd recommend to create a partition for your file system at offset 16MiB from the start of the disk, that way you should also be sure that u-boot don't share a flash erase block with the file system, thus less likely to corrupt u-boot during a power outage for instance.
Use e.g. Gparted for creating the partition for the file system at the right offset, then "dd if=u-boot.imx of=/dev/sdc bs=1k seek=1", and you should be good to go.
977件の閲覧回数
saida
hi
its working when i did dd on sdc
thank you thomas its very helpful and i am following posts to port linux kernel,root filesystem if anything required i will come back to you
thank you  much
byee
