which registers The Register of DDR IC ?
503件の閲覧回数
takashitakahash
Hi community.
Described on The Hardware development Guide 3.5.1 Swapping data lines, NOTE If byte lane swapping was done, target DDR IC register read value must be transposed according to the data line swapping.
which registers The  Register of DDR IC is?
392件の閲覧回数
Hi Takashi
description implies case when processor tries to read DDR memory
Mode Register, when swapping bytes, one needs to foresee where
data will be read. Since it may be not byte0, but on other place.
393件の閲覧回数
Hi Takashi
