Hi everyone,
I have some trouble use USB on Linux (3.10.32). I only use USB1. My device tree is :
apbx@80040000 {
usbphy1: usbphy@8007e000 {
status = "okay";
ahb@80080000 {
usb1: usb@80090000 {
status = "okay";
But I can access to my USB Masse Storage.
When I run "dmesg" I observe this line :
imx_usb 80090000.usb: pinctrl get/select failed, err=-19
I think I miss some options. Anyone have an idea to slove this problem ?
Thanks in advance
Kernel 3.10 was the one of the early mainline kernels that had USB support on mx28.
I would suggest you to use a more recent one, such as 4.1, for example.
Fabio Estevam
Another information : I have an old project with linux 2.6.35.3 and USB is working fine, so I am surprised that their is trouble with linux 3.10...
Why their is an more issue with a newer version of linux ?
Thank in advance
Is the only issue you see the "imx_usb 80090000.usb: pinctrl get/select failed, err=-19" message?
If so, this one is harmless.
Fabio Estevam
I have no other issue, but this one involves I can't use USB (specially USB masse storage). I try to use usb driver (chipidea) from linux 3.18.20. After importing and adapting them to linux 3.10.32, I have no more this issue. But some USB key doen't be recognized correctly. I continue for a time to find why, but if it is impossible to recognize without problem USB masse storage, I would have to change to a newer version.
If so, is usb support in 3.18.12 enough to have an stable usb ?
Thank in advance ?
Gilles,
It would be better to give kernel 4.1.5 a try and see if you still see issues with it.
Fabio Estevam
Fabio,
Sorry for the delay,
It's impossible for me to use a so recent kernel 'cause I need to use Xenomai... I will check some other xenomai compatible version and I will post here which versions work in my case
