Hi thank you for any help.
I have defined from DTSI and from the boot up log, I see mmc1&2 has been initiated, but under the dev I don't see either mmcblk1p1 or mmcblk2p1. I am not sure how to debug this issue. Please give me any point.
From DTSI
mmc0 = &usdhc2; //emmc
mmc1 = &usdhc3; //sd1
mmc2 = &usdhc4; //sd2
From bootup log
mmc0: SDHCI controller on 2194000.mmc [2194000.mmc] using ADMA
mmc2: SDHCI controller on 2198000.mmc [2198000.mmc] using ADMA
mmc1: SDHCI controller on 219c000.mmc [219c000.mmc] using ADMA
thank you.
Thank you for your interest in NXP Semiconductor products,
Could we confirm that:
Could you share the following outputs in a .txt?
# ls -l /dev/
# dmesg
Also, what processor are you working with?
Thanks in advance.
Dear,
thank you for support.
I reviewed the attached file and your answer, I saw that you are using poky reference. Could you please try to use our BSP in the board looking to replicate the issue?
If you are using a third party board, you could ask them if there is anything else to be done.
From your reply:
I was able to cat mmcblk0, mmcblk0p1, and mmcblk0p2
I meant that check the integrity of SDs with a PC host.
I am trying to bring up the Custome board with NXP MCIMX6D7CZK08AD chipset.
In that case, I'd encourage you to try on our BSP and follow this guide which works upon our BSP.
