I buy the Freescale i.MX53 Quick Start board. it's mx53_loco.
I download i.MX53-QSB-Android-Gingerbread-Release4.3 from Reference BSPs for Freescale i.MX53 Quick Start Board.
copy all file of prebulid floder to ..\Profiles\MX53 Linux Update\OS Firmware\files\android\.(Mfgtools tools)
Then open Mfgtools tools,select mx53_smd_android_emmc4.4. Start ,operation Success.
u-boot can't boot from emmc4.4.
I suspect \Profiles\MX53 Linux Update\OS Firmware\files\ucl.xml is error.so I see it.
ucl.xml :
Please use slot3 for MMC4.4 update
The following are the valid inputs when configure the boot
partitions of the eMMC cards.
| Bit7 | Bit6 | Bit5 Bit4 Bit3 | Bit2 Bit1 Bit0 |
| X | BOOT_ACK | BOOT_PARTITION_ENABLE | PARTITION_ACCESS |
Bit7: Reserved
Bit6: always set to vaule '1' when boot_part is enabled
Bit[5:3]:
0x0 : Device not boot enabled (default)
0x1 : Boot partition 1 enabled for boot
0x2 : Boot partition 2 enabled for boot
0x7 : User area enabled for boot
Bit[2:0]:
0x0 : No access to boot partition (default)
0x1 : R/W boot partition 1
0x2 : R/W boot partition 2
So only the '0, 1, 2; 8, 9, 10; 16, 17, 18; 56, 57, 58' are
valid parameters when configure the boot_partiton.
<CMD type="push" body="$ echo 1 > /sys/devices/platform/mxsdhci.2/mmc_host/mmc2/mmc2:0001/boot_config">access boot partition 1</CMD>
<CMD type="push" body="$ echo 8 > /sys/devices/platform/mxsdhci.2/mmc_host/mmc2/mmc2:0001/boot_config">access user partition,and enable boot partion1 to boot</CMD>
<CMD type="push" body="$ echo 2 > /sys/devices/platform/mxsdhci.2/mmc_host/mmc2/mmc2:0001/boot_bus_config">Set boot width is 8bits</CMD>
Red color of the sentences I do not know what that means?
by the way,I test successful u-boot boot from eMMc4.4 by the same u-boot.bin,but not use Mfgtools.Steps are as follows
eMMC 4.3 and 4.4 card support fastboot. To boot from fastboot, please follow below steps:
1. Make sure the slot can support fastboot.
Please check spec for this information. On most of our boards, Slot3 support eMMC fastboot.
2. Program u-boot image to eMMC boot partition.
Normal boot from SD first and program u-boot image to boot partition.
e.g
• Insert normal SD card to slot1 and eMMC 4.3/4.4 card to slot3.
• Normal boot from SD slot1.
• Write u-boot.bin to eMMC card boot partition.
e.g
> mmc read 0 ${loadaddr} 0 0x200
MMC read: dev # 0, block # 0,count 512 ...
512 blocks read: OK
> mmc write 1 ${loadaddr} 0 0x200 1
MMC read: dev # 1, block # 0,count 512 ... partition 1
512 blocks write: OK
3. Get eMMC bus width.
Get boot bit bus mode. Use command “mmcinfo <dev>“ to get bus width.
> mmcinfo 1
Device: FSL_ESDHC
Manufacturer ID: 3
OEM: 5344
Tran Speed: 25000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 3965190144
Bus Width: 4-bit
4. Set eMMC fast boot dip and boot bits.
• Set eMMC fast boot dip.
• Set bus width to the bus width we got from step 3.
5. Reset board for booting.
why u-boot can't boot from eMMc4.4 by Mfgtools?I just say ..
can anybody help me?
