transmit queue 0 timed out (RGMII MAC to MAC - i.MX6Q)
weichao_li1
hello,
我在使用i.MX6Q通过rgmii接口和sja1105通信时,遇到了transmit queue 0 timed out的问题,麻烦支持一下!谢谢!
问题描述:
1)linux内核版本4.14.98。
2)i.MX6Q通过rgmii和sja1105连接,mac to mac,固定为千兆,双工。
3)主要问题是网络不通,ping 100%丢包,过段时间以后出现NETDEV WATCHDOG: eth0 (fec): transmit queue 0 timed out,ping的过程中用示波器测量txc没有时钟信号。
设备树配置:
pinctrl_vmds_enet: vmds_enetgrp {
                            fsl,pins = <
                                   MX6QDL_PAD_RGMII_TXC__RGMII_TXC                  0x1b030
                                   MX6QDL_PAD_RGMII_TD0__RGMII_TD0                  0x1b030
                                   MX6QDL_PAD_RGMII_TD1__RGMII_TD1                  0x1b030
                                   MX6QDL_PAD_RGMII_TD2__RGMII_TD2                  0x1b030
                                   MX6QDL_PAD_RGMII_TD3__RGMII_TD3                  0x1b030
                                   MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL        0x1b030
                                   MX6QDL_PAD_RGMII_RXC__RGMII_RXC                 0x1b030
                                   MX6QDL_PAD_RGMII_RD0__RGMII_RD0                 0x1b030
                                   MX6QDL_PAD_RGMII_RD1__RGMII_RD1                 0x1b030
                                   MX6QDL_PAD_RGMII_RD2__RGMII_RD2                 0x1b030
                                   MX6QDL_PAD_RGMII_RD3__RGMII_RD3                 0x1b030
                                   MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL        0x1b030
                                   MX6QDL_PAD_GPIO_16__ENET_REF_CLK               0x4001b0a8
&fec {
       pinctrl-0 = <&pinctrl_vmds_enet>;
       phy-mode = "rgmii-id";
       fsl,magic-packet;
       fixed-link {
              speed = <1000>;
              full-duplex;
调试过程参考:
1)启动过程信息:
Generic PHY fixed-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=fixed-0:00, irq=POLL)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
fec 2188000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
2)ping和ping后ifconfig结果
root@imx6qvmds:~# ping 192.168.100.10
PING 192.168.100.10 (192.168.100.10): 56 data bytes
^C
--- 192.168.100.10 ping statistics ---
9 packets transmitted, 0 packets received, 100% packet loss
root@imx6qvmds:~# ifconfig
eth0      Link encap:Ethernet  HWaddr 76:D9:14:98:64:99
          inet addr:192.168.100.12  Bcast:192.168.100.255  Mask:255.255.255.0
          inet6 addr: fe80::74d9:14ff:fe98:6499/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:2 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:47200 errors:0 dropped:0 overruns:0 frame:0
          TX packets:47200 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3398720 (3.2 MiB)  TX bytes:3398720 (3.2 MiB)
3)在调试fec过程中发现fec_enet_start_xmit已经被调用,但发送中断没有产生,查看bufdesc_ex的内容cbd_escINTTxBDOffset + A BIT14)设置为1
补充说明:
1)同样的内核代码在imx8qm和qxp上已经测试通过。
2)关于enet中dma的配置,我在imx8的手册上有看到ENET_DMA1CFG,当时imx6的手册上没有找到。
Labels (3)
Tags (3)
Hi weichao
one can check solutions provided on
[PATCH] imx6q: work around fec tx-queue timeouts when SATA/SD + ethernet is active with high through...
weichao_li1
Hi igorpadykov
非常感谢您的回答!
我之前看过这个补丁,但4.14.98内核的fec.h已经修改了
#define FEC_ENET_RX_PAGES 256
#define FEC_ENET_RX_FRSIZE 2048
#define FEC_ENET_RX_FRPPG (PAGE_SIZE / FEC_ENET_RX_FRSIZE)
#define RX_RING_SIZE (FEC_ENET_RX_FRPPG * FEC_ENET_RX_PAGES)
#define FEC_ENET_TX_FRSIZE 2048
#define FEC_ENET_TX_FRPPG (PAGE_SIZE / FEC_ENET_TX_FRSIZE)
#define TX_RING_SIZE 512 /* Must be power of two */
#define TX_RING_MOD_MASK 511 /* for this to work */
#define BD_ENET_RX_INT 0x00800000
aa136466
Have you solved this problem? I also have a headache about this problem.
