"MMC: no card present" issue in u-boot and Kernel does not start
Search instead for
AkiyoshiOhira
When I start SD boot with a custom board based on i.mx8mini, "MMC: no card present" issue in u-boot and Kernel does not start.
The environment in which it is implemented is as follows.
yocto:imx-linux-kirkstone
Kernel: imx-5.15.52-2.1.0.xml
We have confirmed the following:
Execute the following command in u-boot.
u-boot=> mmc dev 0
MMC Device 0 not found
no mmc device at slot 0
u-boot=> mmc dev 1
u-boot=> mmc dev 2
switch to partitions #0, OK
mmc2(part 0) is current device
mmc dev 1 is not recognized.
What should I check and fix?
Attached the "imx8mini_kirkston_uboot.log“ log when the problemed issue.
Best, Regars,
AKiyoshi Ohira
joanxie
AkiyoshiOhira
I checked using the following "i.MX8MMini EVK" demo images, but Kernel does not start.
image used
LF_v5.15.52-2.1.0_images_IMX8MMEVK.zip
 →imx-image-multimedia-imx8mmevk.wic
I also attach the log(imx8mini_demo_images_uboot.log).
Best, Regars,
AKiyoshi Ohira
joanxie
pls let me check your uboot environment by the "pirntenv"
AkiyoshiOhira
I've attached the printenv log.
Best, Regars,
AKiyoshi Ohira
joanxie
how about setting mmcdev to 2 and mmcroot to "/dev/mmcblk2p2 rootwait rw"?
can the board boot up?
