"Getting fatal error: stdio.h: No such file or directory and fatal error: stdlib.h: No such file"
263件の閲覧回数
ParnaSankar
I am trying to compile .c application using cross-compilation with IMX6 ULL yocto build using :
repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-kirkstone -m imx-5.15.71-2.2.0.xml
and getting errors like stdlib.h and stdio.h is missing(No such file or directory).
Can you let me know how to resolve this error?
4 返答(返信)
237件の閲覧回数
Chavira
Hi @ParnaSankar!
Thank you for contacting NXP Support!
Can you attach the log of the error?
I recommend trying to update your packages with "sudo apt update" and "sudo apt upgrade" and install all the required packages for that version are the next:
$ sudo apt-get install gawk wget git-core diffstat unzip \
texinfo gcc-multilib \
build-essential chrpath socat cpio python python3 python3-pip \
python3-pexpect \
xz-utils debianutils iputils-ping python3-git python3-jinja2 \
libegl1-mesa libsdl1.2-dev \
pylint3 xterm rsync curl zstd pzstd lz4c lz4 libssl-dev
Best Regards!
Chavira
226件の閲覧回数
ParnaSankar
Hello @Chavira ,
Thanks for your response.
We are facing the below issue while cross compiling .c applications for imx6 ULL arm platform on x86 linux host machine.
Please find the below error logs :
per_receive.c:6:10: fatal error: stdio.h: No such file or directory
 #include <stdio.h>
compilation terminated.
per_sock.c:6:10: fatal error: stdlib.h: No such file or directory
#include <stdlib.h>
I tried to install the dependencies and packages using the command shared by you
python3-pexpect \
pylint3 xterm rsync curl zstd pzstd lz4c lz4 libssl-dev "
but we are getting the below prints as well :
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'git' instead of 'git-core'
Note, selecting 'python-is-python2' instead of 'python'
Note, selecting 'pylint' instead of 'pylint3'
E: Unable to locate package pzstd
E: Unable to locate package lz4c
222件の閲覧回数
ParnaSankar
Hello @Chavira ,
For your additional information, I want to inform you that
I found out stdio.h and stdlib.h path and added in the CFLAGS
Example:
CFLAGS += -I~/imx-yocto-bsp/build/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/util-linux/2.37.4-r0/recipe-sysroot/usr/include/
but after that if I start compilation again I a getting the another error:  fatal error: gnu/stubs-soft.h: No such file or directory
210件の閲覧回数
Chavira
Hi @ParnaSankar!
I understand better the problem now.
For this case, I recommend compiling the SDK in yocto to avoid this problem.
You can refer to the next community posts.
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-Yocto-Project-Freescale-Yocto-Proje...
https://community.nxp.com/t5/i-MX-Processors/How-to-build-the-yocto-SDK/m-p/465026
Best Regards!
Chavira
