python GPIO Library and i.mx8m Plus
Search instead for
HumanBehaviorsAI
Hi guys.
I'm starting to use i.mx8m Plus for my Agriculture Project. For my mvp1 I want to do a simple ML demonstration.
  1. I have an NN model for detection weeds and separate ground and correct cultural
  2. The camera sees weeds on the ground
  3. When I got a class of weeds on my frame I want to send a signal to my Electrician Solenoids.
But at this moment I've worked with GPIO on Jetson and Raspberry Pi - I use python library gpio_zero
Maybe here I can get answers or a similar library for NXP processors? I will be glad for any help.
YouTube demonstration
Bio_TICFSL
Hello HumanBehaviorAI,
You can work in that library, but at this time the i.mx8mplus is not supported, however you can change the pins number and name on the /pins file of the GitHub project where GPIO is:
https://github.com/gpiozero/gpiozero
Bio_TICFSL
