need iMX6 Quad HDMI 1920x1200 support
rickchu
Can any one share HDMI 1920x1200 parameters in iMX6?
In current source codes does not have 1920x1200 resolution support yet, need help to this feature request.
- need 1920x1200@60Hz parameters in mxc_edid.c
Rick
Labels (3)
qiang_li-mpu_se
From "VESA and Industry Standards and Guidelines for Computer Display Monitor Timing (DMT)" specification, DMTv1r11.pdf, there are some 1920x1200 timing parameters, maybe you can use them.
qiang_li-mpu_se
rickchu
Dear Qiang,
Thanks for your useful information; and I have succeed bring up HDMI 1920x1200 LCD on our device.
Rick
adc1
I couldn't find DMTv1r11.pdf file. Could someone share 1920x1200 HDMI parameters (mxc_cea_mode item) to add in mxc_edid.c kernel module?
thank you, regards
Andrea
EricNelson
Senior Contributor II
Hi Rick,
Note that you'll lose audio support (or it won't operate properly) since the mode isn't one of the standard "CEA" modes supported by the driver:
     linux-imx6/drivers/video/mxc/mxc_edid.c at boundary-imx_3.0.35_4.1.0 · boundarydevices/linux-imx6 · ...
rickchu
Dear Eric,
Thanks for your notice. Already applying patch file.
Rick
