I am working on mx6ul,and used kernel 3.14.38. In the kernel, I am execute command : make modules ,can get the file,which is configfs.ko, libcomposite.ko and g_zero.ko. Can insmod configfs.ko ,and libcomposite.ko, but I am insmod g_zero.ko. the kernel tell me insmod: can't insert 'g_zero.ko': No such device
HAIBO LIN
Hi HAIBO
does file exist on that path. Had you tried modprobe :
linux - What's the difference between insmod and modprobe? - Stack Overflow
Also may be useful to try latest kernels on
I had loaddown the linux kernel 4.1.15, can compile through the kernel. But the kernel can not run. I use emmc start, how can i config in the kernel???
