mx6ul can not insmod usb gadget device
726 次查看
linhaiboyy
    I am working on mx6ul,and used kernel 3.14.38. In the kernel,  I am execute command : make modules ,can get the file,which is  configfs.ko, libcomposite.ko and g_zero.ko.  Can insmod configfs.ko ,and  libcomposite.ko, but I am insmod  g_zero.ko. the kernel tell me insmod: can't insert 'g_zero.ko': No such device
HAIBO LIN
544 次查看
Hi HAIBO
does file exist on that path. Had you tried modprobe :
linux - What's the difference between insmod and modprobe? - Stack Overflow
Also may be useful to try latest kernels on
http://www.nxp.com/products/software-and-tools/software-development-tools/i.mx-software-and-tools/i....
544 次查看
linhaiboyy
   I had loaddown the linux kernel 4.1.15, can compile through the kernel. But the kernel can not run. I use emmc start,  how can i config in the kernel???
