mx28: pull up GPIO pin seems failed
搜索替代
365 次查看
hwo
Hi all,
     I come across a problem. I initialize the AUART2.RTS pin(Bank 3, ID 11), and enable it to be a output GPIO pin. At the same time, enable the pull up function. But when I read out the HW_PINCTRL_PULL3  register. I get all 0. The settings in others register like MUX, DOUT, DRIVE and DOE are quite normal.  I haven't modified the pinctrl.c file. It's original.
Why this happens?
.name  = "AUART2.RTS",
.id    = PINID_AUART2_RTS,
.fun   = PIN_GPIO,
.strength      = PAD_4MA,
.voltage       = PAD_3_3V,
.drive         = 1,
.pullup        = 1,
.pull          = 1,
.output        = 1,
.data          = 0,
One more question, does the pull up function affect the GPIO's output? According to the MX28RM, it only disable the gate keeper.
Thanks in advance.
标签 (2)
196 次查看
igorpadykov
Hi h k
pull up function does not affect the GPIO's output, however
not all pads have pul-ups, only described in
Table 9-3. i.MX28 Functions with Pullup Resistors  MX28RM
http://cache.freescale.com/files/dsp/doc/ref_manual/MCIMX28RM.pdf
197 次查看
igorpadykov
Hi h k
