mx28: pull up GPIO pin seems failed
次の代わりに検索
366件の閲覧回数
hwo
Hi all,
     I come across a problem. I initialize the AUART2.RTS pin(Bank 3, ID 11), and enable it to be a output GPIO pin. At the same time, enable the pull up function. But when I read out the HW_PINCTRL_PULL3  register. I get all 0. The settings in others register like MUX, DOUT, DRIVE and DOE are quite normal.  I haven't modified the pinctrl.c file. It's original.
Why this happens?
.name  = "AUART2.RTS",
.id    = PINID_AUART2_RTS,
.fun   = PIN_GPIO,
.strength      = PAD_4MA,
.voltage       = PAD_3_3V,
.drive         = 1,
.pullup        = 1,
.pull          = 1,
.output        = 1,
.data          = 0,
One more question, does the pull up function affect the GPIO's output? According to the MX28RM, it only disable the gate keeper.
Thanks in advance.
ラベル(2)
197件の閲覧回数
igorpadykov
Hi h k
pull up function does not affect the GPIO's output, however
not all pads have pul-ups, only described in
Table 9-3. i.MX28 Functions with Pullup Resistors  MX28RM
http://cache.freescale.com/files/dsp/doc/ref_manual/MCIMX28RM.pdf
198件の閲覧回数
igorpadykov
Hi h k
