mirror display in imx6
2,575件の閲覧回数
adnanali
I am trying to get a mirrored display between the LVDS and HDMI.  ldb is mxcfb0 and hdmi is mxcfb1.
if i do not add video=mxcfb0:off in bootargs then the ldb shows up and there is nothing on the HDMI. In this case I can test HDMI by dumping some pixels onto the HDMI frame-buffer by using echo command ..like
echo "hello nxp community" > /dev/fb2.
If I add video=mxcfb0:off in the command line then the primary display is HDMI and there are no frambuffers for the LDB device.
I have already tried "Can I mirror a LVDS channel on HDMI? ​" but it did not prove any good.
Do i need to do something else to support a mirrored display between the two framebuffers ?
PS: ldb is using ipuID=1 displayID=0 ("overlayed") and HDMI is using ipu1 displayID=1.
Moreover what do these kernel parameters do "di0_primary ldb=di1"
4 返答(返信)
1,374件の閲覧回数
adnanali
I need to find a solution to this problem ....kindly bring it to your attention ... Regards
1,374件の閲覧回数
weidong_sun
Hello adnan,
      It seems that you are using Android system , right ?
      For android BSP of i.MX6, mxcfb0 must be used. you can't make it off on command line of u-boot.
Weidong
1,374件の閲覧回数
adnanali
Nope. I am not using it for android. In the config file
# CONFIG_ANDROID is not set
1,374件の閲覧回数
adnanali
I am using kernel 3.14 if that can help you in figuring out the problem. Found there is a lot of updates in ldb in this kernel version as compared to kernel 3.10.
