minimize latency in video streaming
Search instead for
zohargolan
Hi All,
I am in the evaluation phase of the i.mx8m plus for a camera application. I am using boundary device nitrogen8mp for the evaluation purpose.
I am running the following GStream command: gst-launch-1.0 v4l2sink ! waylandsrc
I can stream video from the camera to display with several issues:
1. The video is not occupying the whole display and I still have the desktop header shown on the top
2. I have a latency of about 1/4 sec from camera to display. This is a critical parameter for me and will not work for my requirements.
Is there a way to reduce the latency to a sub frame latency?
I appreciate any comment,
Zohar
zohargolan
This doesn't work in the configuration I have and I am getting
root@nitrogen8mp:~# gst-launch-1.0 v4l2src latency=50 ! waylandsink
WARNING: erroneous pipeline: no property "latency" in element "v4l2src0"
EESTE
I'm running into the same issue.
Did you get a solution to this by any chance?
b36401
As far as I know default latency in gstreamer is 200ms as a compromise between realtime and quality.
You can set something like latency=100 to low the latency.
zohargolan
Hi b36401,
Thank you for your answer.
I would you go about setting the latency to latency =100 like you've mentioned?  Where would you set it up?
Zohar
b36401
I mean you can add "latency=100" into the commandline parameters you pass to gstreamer.
