ltib not compiling linux kernel due to python
1,185件の閲覧回数
AlexanderKelle1
I am trying to compile the linux kernel 3.0.35 by using ltib. I am using the 12.08 BSP. When I try to compile the kernel for the i.mx6 I get this error:
error: failed dependencies:
         usr/bin/python is needed by perf-3.0.35-1
I have python installed in the /usr/bin folder. Does anyone know how to fix the problem. Thanks for your help.
-Alexander Keller
4 返答(返信)
921件の閲覧回数
LeonardoSandova
Specialist I
Not sure if my following comment help: according to the log, python is being look at usr/bin/ but you have it on /usr/bin. As a test, can you open the ltib shell (./ltib -m shell) and call the python interpreter? print the PATH env variable, and make sure /usr/bin is in its value. I just want to make sure ltib is able to find python.
921件の閲覧回数
Huazhi_Hank_Gon
I will do it. Thanks.
Hank
921件の閲覧回数
Huazhi_Hank_Gon
Did you get this problem solved? I have the same problem now.
Hank
921件の閲覧回数
Tarek
Senior Contributor I
Where did you get the  linux kernel 3.0.35 from ?
