low throughput of usb netcard(ECM) on usb3.0
Search instead for
mashaofeng
dear expert:
      we have a 5G module connected to IMX8QXP , a usb ECM netcard is enumerated on imx8 , we use iperf to test download speed , the throughput is only can read to 360Mbit/s , it seems low for usb3.0 ,  and the cpu which used for download process is easily reach to 100%;
     how to improve this performance?
     thanks
Sanket_Parekh
Hi @mashaofeng
I hope you are doing well.
Have you connected net-card with USB3.0 Phy?
Thanks & Regards
Sanket Parekh
mashaofeng
i tried to set follow setting
echo 4 > /sys/class/net/usb1.254/queues/rx-0/rps_cpus
echo 4 > /sys/class/net/usb1/queues/rx-0/rps_cpus
the througput seems higher , but it will show error    xhci-cdns3: ERROR unknown event type 37
log is as follow:
[ 15]   3.00-4.00   sec  5.63 MBytes  47.2 Mbits/sec
[ 17]   3.00-4.00   sec  5.64 MBytes  47.3 Mbits/sec
[ 19]   3.00-4.00   sec  6.03 MBytes  50.6 Mbits/sec
[SUM]   3.00-4.00   sec  50.7 MBytes   426 Mbits/sec
[  135.713185]  xhci-cdns3: ERROR unknown event type 37
[  136.013749]  xhci-cdns3: ERROR unknown event type 37
[  136.067157]  xhci-cdns3: ERROR unknown event type 37
[  136.073563]  xhci-cdns3: ERROR unknown event type 37
