imx8qxp pcie internal Clock
Search instead for
yangxu
To consider BOM cost, i will use internal clock, PCIE module will generate clock onPCIE_REFCLK100M_P/PCIE_REFCLK100M_N \PCIE_REFCLK100M_P/PCIE_REFCLK100M_N to the bluetooth module.How do I modify which register?
igorpadykov
Hi Yang
one can try ext_osc = <0>; in &pcieb{..  imx8x-mek.dtsi
https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm64/boot/dts/freescale/imx8x-mek.dt...
