imx8qxp parallel csi pclk-sample
songhongliang
HI
imx8qxp parallel csi的pclk-sample可以设置为双边沿采样吗?如果可以, 该怎么设置?
Can the pclk sample of imx8qxp parallel csi be set as bilateral edge sampling? How to set if possible?
Thanks!
joanxie
unfortunately, imx8qxp parallel csi doesn't support this
songhongliang
imx8qxp parallel csi可以像mipi csi那样有虚拟通道吗?我想用 parallel csi扩展AHD摄像头。比如 一路 parallel csi转两路AHD.
Can imx8qxp parallel csi have virtual channels like mipi csi? I want to expand the AHD camera with parallel csi. For example, one parallel csi to two AHDs
joanxie
you can refer to the reference manual, only mipi csi supports virtual channels
