imx8mq: thermal: Industrial grade trip_point setting
967件の閲覧回数
xoduddk123
I'm using the industrial grade of the i.MX 8M.(MIMX8MQ6CVAHZAB)
In the device-tree, there is something related to temperature.
	thermal-zones {
		cpu-thermal {
			polling-delay-passive = <250>;
			polling-delay = <2000>;
			thermal-sensors = <&tmu 0>;
			trips {
				cpu_alert: cpu-alert {
					temperature = <80000>;
					hysteresis = <2000>;
					type = "passive";
				cpu-crit {
					temperature = <90000>;
					type = "critical";
/sys/devices/virtual/thermal/thermal_zone0# cat trip_point_0_temp
80000
/sys/devices/virtual/thermal/thermal_zone0# cat trip_point_1_temp
90000
When using the Industrial grade of the i.MX 8M, is it okay to raise this standard as follows?
passive: 90
critical: 100
U-Boot: rel_imx_5.4.70_2.3.0
Kernel: rel_imx_5.4.70_2.3.0
regards,
kwon
954件の閲覧回数
Yuri
@xoduddk123
  Temperature of 100 C is very high, since temperature sensor
accuracy of 10 C is not taken into account there.
  Default settings in our BSP may be left as is.
The temperature settings  in themselves are not the problem for thermal considerations:
the main problem is how to implement optimal power dissipation in system.
   Also:
https://community.nxp.com/t5/i-MX-Processors/i-MX8M-mini-thermal-zone-issue-passive-critical-trip-po...
Yuri.
955件の閲覧回数
Yuri
@xoduddk123
   Also:
Yuri.
