I am facing a problem when m4 using i2c and spi resources in Android(bootmcu && boota mmc0), m4 will block.
But if I just run m4 at uboot(only bootmcu), it runs OK.
And also m4 runs OK, if m4 does not use i2c or spi resources in Android(bootmcu && boota mmc0).
I am sure I have disabled i2c and spi resources and pinmux in linux kernel device tree(imx8mq-evk.dts).
So what's the possible reason? Am I missing any configurations(RDC or clock configurations)?In my opinion, m4 will run OK if resource will not conflict between m4 and linux.
Thanks .
Edward
You're correct, you need to disable the peripherals that it would be used by M4 when running Cortex-A and Cortex-M at the same time.
Please check that in your code you're not using other peripherals. Also, please note that you'll need to reserve UART2, since it is used by the Cortex-M by default for terminal.
Aldo.
Thanks.
I'd like to know how to disable peripherals in A53, in other words, how to configure RDC in A53.
Br
Edward
You may refer to the RDC SDK example located at:
<sdk_path>\boards\evkmimx8mq\driver_examples\rdc
Aldo.
I know what you mean. There is no need to configure RDC module in linux kernel? Where and how to configure RDC module in linux kernel.
Br,
Edward
