1.question 1:
and when the cpu enter suspend mode ,it will waked up by RTC regularly.the log is attached.
I don't know why why the RTC wake up the cpu .is it normal or abnormal?
2.question2:
by click power key ,we can enter suspend mode,and I want to know how we can enter into idle mode.
could you please tell me how to enter idle mode?
Wei
已解决! 转到解答。
Hi Wei
one can look at RTC wake up in unit test and check if these codes are used in
custom software
rtcwakeup.c\mxc_rtc\test - imx-test - i.MX Driver Test Application Software
idle mode usage is described in sect.2.5 Power Management i.MX Linux Reference Manual
"IDLE Mode: This mode is defined as a mode which CPU can automatically enter
when there is no thread running and all high-speed devices are not active."
Hi Wei
custom software
