I need more accurate temperature reporting for the imx8mm processor. Empirical data taken using the linux source code currently does NOT use the factory calibration values for the TMU.
The driver source code is located here:
https://github.com/nxp-imx/linux-imx/blob/lf-6.1.y/drivers/thermal/imx8mm_thermal.c
5.4.5 Temperature Sensor Error Correction Method.
, where Tsense=readl_relaxed(tmu->base + TRITSR) & TRITSR_TEMP0_VAL_MASK;
ERR051272: TMU: Bit 31 of registers TMU_TSCR/TMU_TRITSR/TMU_TRATSR invalid Description: Bit 31 of registers TMU_TSCR/TMU_TRITSR/TMU_TRATSR might be set as invalid value when the temperature varies in range.
Workaround: Do not use Bit 31 of registers TMU_TSCR/TMU_TRITSR/TMU_TRATSR. Suggest to read TMU value and use 1 point calibration to justify if the temperature is in range.
解決済! 解決策の投稿を見る。
For Q1: No, default driver from NXP doesn't implement the following formula
For Q2, These are correct locations about TE1/TE2 from internal case.
0x3035_04F0[7:0] TSENSOR_VALUE_RT[7:0] (room temp)
0x3035_04F0[15:8] TSENSOR_VALUE_HT[7:0] (high temp)
For Q3:
For Q4, these references in i.MX8MM RM are not correct. These bits are in i.MX8MQ RM.
ALPF--> TMU_TER [ALPF]
ME-->MU_TER [EN]
MSITE-->ignore this bit in i.MX8MM. There are three monitor sites in i.MX8MQ TMU. But for i.MX8MM, there is only one site. You can find that with address offset.
For Q5, i can't find more description about ERR051272 from internal material. Please refer the workaround, Do not use Bit 31 of registers TMU_TSCR/TMU_TRITSR/TMU_TRATSR.
For example, The temperature is reported with an "invalid value" but is high AND still within bounds of VER1_TEMP_LOW_LIMIT and VER1_TEMP_HIGH_LIMIT.
--> This is correct explanation. That's why NXP not use V bit in the current driver.
Best Regards
Zhiming
Checking to see if anyone can help with this?
For Q3:
ME-->MU_TER [EN]
Best Regards
Zhiming
Follow up to
1.L6.6.y BSP will contain the patches you mentioned in future release.
2.Technical support doesn't have more document about SECRET UNDOCUMENTED TMU REGISTERS. So we can't give you more information.
3.For last question, need time to confirm.
