In the link below it says with HAB V4.1.2 it's possible to use a single SRK to authenticate both CSF and Image contents.
Could you let me know what modifications we need to make to the corresponding csf.txt files?
I am using Yacto Zeus build to test on my imx8mm evaluation kit. How to check which version of HAB V4 currently being used in my setup?
@mukunda9g
Use section 5.1.1 (Generating PKI tree for fast authentication) of AN4581
(i.MX Secure Boot on HABv4 Supported Devices).
https://www.nxp.com/docs/en/application-note/AN4581.pdf
For more details on key generation for CST, see HAB CST User Guide,
https://www.nxp.com/webapp/Download?colCode=IMX_CST_TOOL_NEW&location=null
i.MX8Mm supports fast authentication.
Yuri.
