imx8m mini flash img error
Search instead for
1269813285
I develop a custom board with imx8m mini ,when we execute the command
"sudo ./uuu_imx_android_flash.sh -f imx8mm -u ddr4 ",
the result is failed .it stop at the result
"3:13 1/ 1 [=================100%=================] SDP: boot -f u-boot-imx8mm-ddr4-evk-uuu.imx "
we doubt whether it is because of the ddr4.
I noticed that the reference board using 2*16bit DDR4 for memory interface for 32bit data, and we used 16 bit DDR4 for memory for 16 bit data.
I wonder whether it is the cause of our problem.
Maybe we need to modify some code or configuration, Could you please give us some tips?
gusarambula
Hello Tang Wei,
If you are using a custom board, you would need to make adjustments as mentioned on the following threads:
https://community.nxp.com/thread/519435
https://community.nxp.com/thread/521347
In the first, it talks about how to setup the information of your board, and on the second it talks about a specific problem when having USB type C settings on uboot for your board.
I hope this helps to shed some light on what may be the issue.
