imx7 uart clock management
1,024 次查看
vsiles
Senior Contributor I
Hi !
In order to run a secure OS along side linux, I'd Linux to stop disabling the clock for UART (at the moment, CCM is still accessible from Linux in the normal world. At some point this will be removed but we are in the early phases of this project).
In order to achieve that, I removed all the clk_disable_unprepare and all the clk_unprepare from drivers/tty/serial/imx.c, but I still end up having UART's TARGET_ROOT value set to 0 sometimes.
Is there another part of the Linux code where uart's clock are disabled ?
Best,
V.
834 次查看
vsiles
In the end, the clocks are fine, it is the whole module that is disabled by Linux. I need to prevent that.
835 次查看
vsiles
