imx6ull turning off during temperature test (thermal_zone0)
929 次查看
brunoferrarezi
Hi all friends from NXP and forum colleagues,
We have here ond NXP Kit (EVK based on SCH-28617 PDF: SPF-28617).
We are testing temperature rise with this EVK and have observed that the message below appears when the test equipment that raises the temperature is at 40°C. See below:
[ 1481.858375] thermal thermal_zone0: critical temperature reached (90 C), shutting down
[ 1484.017871] thermal thermal_zone0: critical temperature reached (90 C), shutting down
[ 1485.139445] thermal thermal_zone0: critical temperature reached (90 C), shutting down
[ 1486.258514] thermal thermal_zone0: critical temperature reached (90 C), shutting down
[ 5.316041] reboot: Power down
When We tried to read the temp We got that information:
cat /sys/class/thermal/thermal_zone0/temp
71149
Could anyone tell me if I need calibrate something to decrease the temperature difference and how I can do that?
BR!
标签 (3)
894 次查看
brunoferrarezi
Hello @JorgeCas ,
Thanks for your message.
We are using Buildroot 2020.02.1.
There is a way to modify those values ? I'm measure the processor casing and the temperature that linux show is around 20°C above what I'm measuring.
We checked with a temperature camera and the temperature appears to be 20 degrees above what is being measured.
Wainting your comments.
887 次查看
JorgeCas
Did you try with our latest official BSP? If not, could you please try it?
Best regards.
898 次查看
JorgeCas
When reaching passive point, cooling device will notify CPU to run at a lower frequency (trip_point_0_temp).
When the temperature drops to 10 °C below passive point, cooling device will release all the cooling actions.
When reaching critical point, cooling device will shut down the system (trip_point_1_temp).
cat /sys/class/thermal/thermal_zone0/trip_point_0_temp
cat /sys/class/thermal/thermal_zone0/trip_point_1_temp
This is also defined on imx_thermal.c.
Which Linux version are you using?
Best regards.
