imx6sx mxsfb error with QT5
702 次查看
peterbärtsch
We have only 256M RAM on our board. When I start QML Application I get mxsfb 2220000.lcdif: Unable to allocate framebuffer memory
cma: CMA: reserved 96 MiB at 8a000000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @89db1000 s8320 r8192 d16256 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk3p2 rootwait rw
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 146900K/262144K available (7035K kernel code, 394K rwdata, 6144K rodata, 320K init, 429K bss, 115244K reserved, 0K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0x90800000 - 0xff000000   (1768 MB)
    lowmem  : 0x80000000 - 0x90000000   ( 256 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x80ce6e80   (13180 kB)
      .init : 0x80ce7000 - 0x80d37080   ( 321 kB)
      .data : 0x80d38000 - 0x80d9a980   ( 395 kB)
       .bss : 0x80d9a98c - 0x80e05dd8   ( 430 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
    RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1
I increase the CMA memory to 160M (on EVK) and than it works. But on our board I can configure only 96M otherwise I get kernel panic.
Is the GPU Memory on a fix address or why does it not work with less then 160M CMA memory?
Peter
标签 (2)
506 次查看
peterbärtsch
I solve it with  QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1
Peter
507 次查看
peterbärtsch
Peter
