I'm using yocto root filesystem on a custom hardware (using imx6q) that is based on sabre-sd.
I'm trying to get accelerated X-windows system. The vivante_dri.so (I think is the key element) required in enabling the acceleration is failing when X tries to come up and X resorts to software rendering.
My application runs on Java Vm and uses SWING UI.
Is there any imx6 platform out there which has used accelerated X-window system ?
Anyone has an alternative suggestion?
Any inputs might be of help to me.
-Pj
Forgot to add, I'm using linux 3.0.35.
