imx6 CAN wakes up Linux immediately
搜索替代
1,123 次查看
akbar123
I can wake Linux up using UART by enabling its wakeup capability:
    $ echo enabled > /sys/class/tty/ttymxc0/power/wakeup
I have put Linux into sleep using the following command:
    $ echo mem > /sys/power/state
then sending a character over UART when the Linux is in sleep to wake it up... This scenario works well.
I want to do the same with CAN, so I enable its wakeup capability:
    $ echo enabled > /sys/class/net/can0/device/power/wakeup
Then put Linux into sleep. It shows that Linux goes into sleep, but it immediately wakes up. I want Linux to be woken up upon the reception of a frame over CAN, just like the UART scenario
Hardware: apalis imx6D ixora v1.2
OS: Linux 5.4.91-33088-g8c05b31a44c3
Question: What could be the problem? How can I do that?
Thanks in advance
标签 (2)
标记 (3)
1,062 次查看
akbar123
I used NXP Linux kernel from https://source.codeaurora.org/external/imx/linux-imx and the problem fixed
$ git clone https://source.codeaurora.org/external/imx/linux-imx/
$ git checkout -b 4.19 remotes/origin/imx_4.19.35_1.1.0
$ make imx_v7_defconfig
$ make -j$(nproc) zImage
$ make imx6q-apalis-ixora-v1.1.dtb
$ make -j$(nproc) modules
Now I can put Linux into sleep and wake it up by sending a CAN frame to it:
Enable CAN wakeup feature:
$ cd /sys/devices/soc0/soc/2000000.aips-bus/2094000.flexcan/power
$ echo enabled > wakeup
Put Linux into sleep:
Now, by using another board to send a CAN frame, I can wake up Linux
6 回复数
1,116 次查看
Hi Asghar
one can try below procedure:
Connect two boards CAN port.
On one board A,
Listen to CAN port.
Enable CAN wakeup:
find /sys -name "wakeup" | grep -i can
e.g.
find /sys -name "wakeup"|grep -i can
/sys/devices/platform/soc/30800000.aips-bus/30a10000.can/power/wakeup
Get all CAN wakeup control points and enable wakeup:
e.g.
echo enabled > /sys/devices/platform/soc/30800000.aips-bus/30a10000.can/power/wakeup
<enable remaining CAN ports too>
Suspend the board:
On the other board, send data to CAN port.
Then board A will wake up.
1,096 次查看
akbar123
I guess there might be some problem with driver
I tested two different Linux kernel versions available in Toradex Linux built with apalis_imx6_defconfig :
5.4: Linux goes to sleep and immediately wake up
4.9: Linux goes to sleep and does not wake up upon receiving a CAN frame
What kernel version do you use?
1,080 次查看
may be suggested to try with NXP Sabre SD reference boards.
nxp supports only official linux releases from source.codeaurora.org/external/imx/linux-imx repository
https://source.codeaurora.org/external/imx/linux-imx/tree/?h=imx_5.4.70_2.3.0
Documentation
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
1,063 次查看
akbar123
1,112 次查看
akbar123
It has the same result. Linux will go into sleep, BUT it immediately wakes up.
I expect that upon the reception of a CAN frame, It wakes up... But I see something else in practice
1,101 次查看
this may depend on used hardware, apalis boards are developed and supported
by third party toradex and issue may be posted on community
https://www.toradex.com/community
