I'm porting u-boot 2013 for my custom board with imx51.
In U-boot from Freescale (2009) I had one u-boot.bin file,
I had to put it at the beginning of parallel NOR flash memory (TEXT_BASE = 0xB0000000).
Now (U-boot 2013) I have two files: u-boot.imx and u-boot.bin.
When I boot from sd cart I use *.imx file (everything works fine and what is important for the rest -> u-boot sees a flash memory, for example, I can use "flinfo",
so I assume that the basic configuration is correct ),
but when I tried to boot from NOR Flash (using *.imx file at the start of NOR flash memory -> 0xB0000000) device does not respond.
Compared to the configuration for SD I changed:
in imximage.cfg:
BOOT_FROM nor
in configuration file: mx51evk.h
CONFIG_SYS_TEXT_BASE = 0xB0000000
#define CONFIG_SYS_FLASH_CFI
#define CONFIG_FLASH_CFI_DRIVER
#define CONFIG_SYS_FLASH_BASE 0xB0000000
#define CONFIG_SYS_FLASH_SIZE 1024
#define CONFIG_SYS_FLASH_PROTECTION 1
#define CONFIG_SYS_MAX_FLASH_BANKS 1
#define CONFIG_SYS_MAX_FLASH_SECT 2053
#define CONFIG_ENV_IS_IN_FLASH 1
#define CONFIG_ENV_SIZE (8*1024)/*0x40000
#define CONFIG_ENV_OFFSET (6 * 64 * 1024)
So I wonder if maybe I'm using wrong file, or can I put it with some offset
or I miss something in the configuration file?
Hardware configuration for booting from Parrallel Nor Flash (Fuse bits) is in 100% correct.
I will be grateful for your help
Lukas
