[imx28] connecting usb hub in Linux
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hello
I'am running Linux 3.11 on imx28(board TX28 from KARO) when I connected usb hub to usb host it seems to be detected properly:
usb 1-1: new high-speed USB device number 17 using ci_hdrc
ci_hdrc ci_hdrc.0: port 1 reset complete, port enabled
ci_hdrc ci_hdrc.0: GetStatus port:1 status 18001205 12 ACK POWER sig=se0 LPM PE CONNECT
usb 1-1: udev 17, busnum 1, minor = 16
usb 1-1: New USB device found, idVendor=04b4, idProduct=6560
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
usb 1-1: usb_probe_device
usb 1-1: configuration #1 chosen from 1 choice
usb 1-1: adding 1-1:1.0 (config #1, interface 0)
hub 1-1:1.0: usb_probe_interface
hub 1-1:1.0: usb_probe_interface - got id
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
But when i connect something to the hub i got:
ci_hdrc ci_hdrc.0: port 1 remote wakeup
usb usb1: usb wakeup-resume
usb usb1: usb auto-resume
ci_hdrc ci_hdrc.0: resume root hub
hub 1-0:1.0: hub_resume
hub 1-0:1.0: port 1: status 0507 change 0000
hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
ci_hdrc ci_hdrc.0: GetStatus port:1 status 18001a85 12 ACK POWER sig=j LPM SUSPEND PE CONNECT
usb 1-1: usb wakeup-resume
usb 1-1: usb auto-resume
hub 1-0:1.0: port 1 status 0000.0507 after resume, -19
usb 1-1: can't resume, status -19
hub 1-0:1.0: logical disconnect on port 1
hub 1-0:1.0: resume on port 1, status -19
hub 1-0:1.0: port 1, status 0507, change 0004, 480 Mb/s
usb 1-1: USB disconnect, device number 17
usb 1-1: unregistering device
usb 1-1: unregistering interface 1-1:1.0
usb 1-1: usb_disable_device nuking all URBs
ci_hdrc ci_hdrc.0: port 1 reset error -110
hub 1-0:1.0: hub_port_status failed (err = -32)
hub 1-0:1.0: port_wait_reset: err = -32
hub 1-0:1.0: port 1 not enabled, trying reset again...
I found similar not resloved issue here Problem connecting USB 2.0HUB to i.MX28 custom board.
I reached to Linux ReleaseNotes.txt on KARO BSP and there is a note:
Known bugs:
- USB: devices connected to a HUB only work, if the HUB is
connected to the USB port with all devices attached
I checked kernel version 3.18 and the problem seems not resolved. I have two questions regarding this situation:
1.(the most important) Does anyone have a solution for this
2.(less important) What is the reason? Hardware or software?
Thanks in advance for Your answers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I know this is an old thread, but just faced this problem today.
Passing 'usbcore.autosuspend=-1' into the kernel command line solved the issue for me.
Fabio Estevam
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
that helped me with LS1021A IoT board!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi randalsteve
according to answer on that link, mx23-olinuxino board has a
smsc usb hub and it works fine, so seems this is specifc BSP bug,
suggest to post that on Karo forum.
