imx 6 platform using gstreamer to displaye 4 camears,when quit, the kernel panic
xiaoqiya
My Command as follow:
gst-launch v4l2src device=/dev/video0  ! 'video/x-raw-yuv, format=(fourcc)UYVY' ! queue ! mfw_isink disp-width=512 d
gst-launch v4l2src device=/dev/video1  ! 'video/x-raw-yuv, format=(fourcc)UYVY' ! queue ! mfw_isink disp-width=512 d
gst-launch v4l2src device=/dev/video2  ! 'video/x-raw-yuv, format=(fourcc)UYVY' ! queue ! mfw_isink disp-width=512 d
gst-launch v4l2src device=/dev/video3  ! 'video/x-raw-yuv, format=(fourcc)UYVY' ! queue ! mfw_isink disp-width=512 d
when i want to shutdown the camera, i use "kill -2 pid1 pid2 pid3 pid4" ,but the system damaged and the following error appears:
ExecuUnable to handle kernel paging request at virtual address ca499000
tion ended after 1000159667 ns.
pgd = b8524000
h[ca499000] *pgd=4886e811andling interrupt.
Interrupt: St, *pte=00000000opping pipeline ...
Execution en, *ppte=00000000ded after 1000581001 ns.
Setting
Setting Internal error: Oops: 807 [#1] PREEMPT SMP
Modules linked in:
CPU: 0    Not tainted  (3.0.35 #2)
PC is at memcpy+0x50/0x330
LR is at 0x407040c0
pc : [<802355b0>]    lr : [<407040c0>]    psr: 20000113
sp : b80a7d54  ip : 407040c0  fp : 80afda70
r10: 00000b40  r9 : 8003d278  r8 : 407040c0
r7 : 407040c0  r6 : 407040c0  r5 : 407040c0  r4 : 407040c0
r3 : 407040c0  r2 : 00000180  r1 : ff9949e0  r0 : ca499000
Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c53c7d  Table: 4852404a  DAC: 00000015
Process gst-launch-0.10 (pid: 3401, stack limit = 0xb80a62f0)
Stack: (0xb80a7d54 to 0xb80a8000)
The probability of the error is more than 50%(other 50%   4 cameras quit normal).
Is there any other methods to quit gstreamer or is there bug in the official plugins of v4l2src or mfw_isink?
who can help me ...thanks
Hi XiaoQi
please check below how to crrectly stop pipeline
reg: gst-launch stop command
