imx.6, EIM in burst mode, can BCLK be continuous?
2,171 次查看
fjeanson
We know that BCM is:
0: The burst clock runs only when accessing a chip select range with the SWR/SRD bits set. When the burst clock is not running it remains in a logic 0 state.
1 : The burst clock runs whenever ACLK is active (independent of chip select configuration)
why is there this note in the reference manual of imx.6 (rev2, 06/2014) section 22.9.7, p.1073, BCM bit:
"NOTE: This bit should be used only in async. accesses. No sync access can be executed if this bit is set."
I assume "used" means "1", and that "sync access" means SRD and SWR are set to 1.
in other words, can we have BCLK continuous in burst mode?
Thanks, Francis
标记 (3)
1,359 次查看
Yuri
  The i.MX6 DQ does not have special PLL for providing continuous BCLK, synchronized
with internal (system bus) ACLK. This feature is supported in i.MX6 S/DL. So, for i.MX6 DQ
we cannot guarantee, that BCLK in continuous mode is fully synchronized with ACLK.
This is why it was stated that the  continuous mode is intended mainly for debugging
(under the i.MX6 DQ). Nevertheless,  some customers use it.
  As for i.MX6 S/DL, please take a look at section 22.5.1 (Continuous BCLK) for further
details of the i.MX6 S/DL Reference Manual (IMX6SDLRM, Rev. 1, 04/2013).
Yuri
1,359 次查看
dank1
I tried activating the BCLK continuously on my i.MX6 Dual/Quad by setting ('1') the BCM bit (bit 0) on the EIM_WCR (0x021B_8090h) register.
I am not getting any clock on BLCK - constant '0'.
Did I forget anything?
1,359 次查看
Yuri
  When using an continuous BCLK in synchronous mode, BCD MUST be set to 0.
Please check it.
~Yuri.
1,360 次查看
Yuri
Yuri
