Hello.
I am looking to enable secureboot in the Yocto zeus branch for iMX8mm.
I am using the following repo link to initialize the repository:
repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-zeus -m imx-5.4.3-2.0.0.xml
In order to use coresight, I need the Embedded Trace Macrocell (ETM) for each core defined in a devicetree, but can not find the address for this board. If I can get the location of the ROM table then I can find the offset for each core (see https://developer.arm.com/documentation/ddi0500/d/debug/rom-table/rom-table-register-summary).
This post is requesting the address of said ROM table, or the devicetree file to enable coresight components.
-Mitch
Hi Mitch
one can look at suggestions provided on
https://community.nxp.com/t5/i-MX-Processors/openocd-imx8-coresight-address-help/m-p/608904
