Hi, I'm working on a iMX8M Mini EVK (official NXP Android bsp) and I want to use the UART4 , formally used as debug
port for M4 microcontroller .
Changed the DTS file to include the UART:
/*pin muxing */
pinctrl_uart4: uart4grp {
fsl,pins = <
MX8MM_IOMUXC_UART4_RXD_UART4_DCE_RX 0x140 /* GPIO5.28 */
MX8MM_IOMUXC_UART4_TXD_UART4_DCE_TX 0x140 /* GPIO5.29 */
&uart4 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart4>;
assigned-clocks = <&clk IMX8MM_CLK_UART4_SRC>;
assigned-clock-parents = <&clk IMX8MM_SYS_PLL1_80M>;
/* status = "disabled"; */
status = "okay";
But system will go in crash when accesing the first UART4 register.
Problem is that the RDC register @ 303d0518 is set to 0xFC, so UART is assigned to M4 core:
A workaround is to set a macro in UBOOT to set register to 0xFF:
setenv ena_uart4 mw.l 0x303D0518 0xFF
setenv bootcmd 'run ena_uart4; boota mmc0'
Problem is that in UBOOT code I was not able to detect where the register is initially set to 0xfc:
a patch placed into board_early_init_f() do not works as expected, and it was impossible to
assign the UART4 to UBOOT console ...
Any idea where to find this setting?
M. Sangalli
