iMX8M Plus ISP on Android - how to enable AutoFocus function ?
DVideray
Hi all,
I'm working on implementing auto focus function of ISP on iMX8M Plus under Android for AR1335 camera with DW9790 focus lens driver.
I was able to compile libar1335.so for ISP-IMX and getting image and even see ISP trying to set focus (based on TRACE/DEBUG output). DW9790 driver inserted successfully too, but where are no IOCTL calls to it to set/change focus. Now I noticed that all ISI focus related methods are empty for the only sources code example available to public, specifically OS08A20.c
So, my question, do I have to implement them and if so, where I can get an example ?
Or I'm on the wrong path ?
Thank you in advance!
static RESULT AR1335_IsiFocusSetupIss(IsiSensorHandle_t handle)
    TRACE(AR1335_INFO, "%s (enter)\n", __func__);
    TRACE(AR1335_INFO, "%s: (exit)\n", __func__);
    return RET_SUCCESS;
static RESULT AR1335_IsiFocusReleaseIss(IsiSensorHandle_t handle)
    return RET_SUCCESS;
static RESULT AR1335_IsiFocusGetIss(IsiSensorHandle_t handle, IsiFocusPos_t *pPos)
    return RET_SUCCESS;
static RESULT AR1335_IsiFocusSetIss(IsiSensorHandle_t handle, IsiFocusPos_t *pPos)
    return RET_SUCCESS;
static RESULT AR1335_IsiGetFocusCalibrateIss(IsiSensorHandle_t handle, IsiFoucsCalibAttr_t *pFocusCalib)
    return RET_SUCCESS;
malik_cisse
Senior Contributor I
Hi @DVideray
You must be using quite old version of isp-imx.
In newer version (I believe from v18 on. Current version is v22 if I am not wrong) these functions are implemented.
For example, if you download and deploy (simply execute *.bin file on Ubuntu host), you will see that all above function are filled with life.
isp-imx v20 (in link bellow, you can replace 20 with other numbers to download the version u want):
https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/isp-imx-4.2.2.20.0.bin
DVideray
I just downloaded it again and where is no ar1335.c at all and os08a20.c example have empty autofocus  related methods. I believe, NXP removed those from the package for some reason.
joanxie
current bsp doesn't support ar1335 as default, for os08a20, pls find the path as below
isp-imx-4.2.2.22.0/units/isi/drv/OS08a20/source/
malik_cisse
Hi @joanxie
What is actually the point of adding drivers in earlier versions and removing them afterwards?
joanxie
what kind of driver adding you mean? could you give me a copy of what you need from old version? let me double check it, I only have 6.1 bsp version right now
DVideray
AR1335.c (with implemented AutoFocus fuctions) and dewarp XML and JSON files from ISP-IMX/units/isi/drv directory present in original 4.2.2p18 release, but deleted afterwards.
I also interested in reasons why it was removed after releasing. It doesn't work properly? Some kind of NDA violations? or what ?
DVideray
It's worse! Support for ar1335 and Auto-Focus removed from all releases, including 4.2.2p18 and p19.
I hope to get some explanation and future release plans, so we can plan HW/SW development on our end.
joanxie
I don't think we have tested this driver(ar1335_mipi_v3.c) since current nxp imx8mp board doesn't support ar1335 as default, but I found internal team tested ar1335 on nxp converter board, but I couldn't share the patches here, if you need it, let me check how you can get it
jnettlet
Would it be possible for you to share the patches? We have also have a customer that has developed a camera module based on the ar1335 and has found the support missing now.  Thanks
DVideray
The piece I'm missing is AutoFocus functions/methods implementation example for OS08A20.c
Best regards!
joanxie
function of IsiFocusSetIss, which is called by AF algorithm and then set focus position to Driver under vvcam/v4l2/focus/vcm_dw9790/dw9790.c
DVideray
Correct. Current example of sensor driver for OS08A20.c for ISP looks like this:
static RESULT OS08A20_IsiFocusSetupIss(IsiSensorHandle_t handle)
    TRACE(OS08A20_INFO, "%s (enter)\n", __func__);
    TRACE(OS08A20_INFO, "%s: (exit)\n", __func__);
    return RET_NOTSUPP;
static RESULT OS08A20_IsiFocusReleaseIss(IsiSensorHandle_t handle)
    return RET_SUCCESS;
static RESULT OS08A20_IsiFocusGetIss(IsiSensorHandle_t handle, IsiFocusPos_t *pPos)
    return RET_SUCCESS;
static RESULT OS08A20_IsiFocusSetIss(IsiSensorHandle_t handle, IsiFocusPos_t *pPos)
    return RET_SUCCESS;
static RESULT OS08A20_IsiGetFocusCalibrateIss(IsiSensorHandle_t handle, IsiFoucsCalibAttr_t *pFocusCalib)
    return RET_SUCCESS;
