iMX8 share DTS informations with the co-processor
搜索替代
123 次查看
Cupcake
For our application we have a Yocto OS on iMX8 that runs some high level applications then we also have a more critical application that runs in the co-processor (cortex-m7).
Currently we have:
  • Linux: a DTS file, that define pinmuxing and driver/interface configuration
  • Cortex-m7: pin_mux.c file generated by MCUExpresso Config Tools.
We would like to integrate the content of pin_mux.c in our main .dts (based on the example generated by MCUExpresso Config Tools).
But the question is:
  • Did you know any ways to declare the GPIO's/Peripheral in the DTS, and access it at runtime using a label from the cortex-m7 ?
For example in our cortex-m7 code, we would like to replace this:
GPIO_PinWrite(GPIO3, 23U, 1U);
By something like this:
GPIO_PinWrite(gpio_port_dts_value("S2LP_CS"), gpio_pin_dts_value("S2LP_CS"), 1U);
Like this, our code in cortex-m7 will be based on DTS/DTB informations and we should have only one file (the DTS) to adapt our applications to the target board.
I know that nordic made this kind of stuffs in Zephyr, that's why I had this idea.
0 回复数
