iMX8 PLUS MIPI raw8
iMX8 PLUS MIPI raw8
2,076 次查看
Creative
Our iMX8 PLUS platform
Our task is to get an image in RAW8 format (10, 12)
AR0521 sensor (4 lines MIPI)
I managed to integrate the driver for the sensor
And get a crooked image, the image is as if divided into 4 parts, the first two squares display the image of the image, the other two are just black.
The questions are as follows:
1) What changes need to be made to the MIPI (CSI) driver to get an image in RAW8 (10, 12)?
2) There is data on the MIPI bus, but there is no CLK, what could be the reason?
Any help would be helpful, thanks
5 回复数
2,022 次查看
Hi Russel
In case of using 5.10.x version of BSP, recommended to try applying the attached BSP patch, verified with OV5640 sensor.
1,620 次查看
JesterOfHw
this was solution to our issue that matched the below image OP added. no more side by side double and half full of NULL.
SOLUTION
标记 (5)
1,935 次查看
chensam
Hi igorpadykov
Can you tell me which the BSP version of the attached BSP patch?
I using imx8mp-evk board with bsp version is 5.10.35, and want to get mipi ov5640 8 bit raw data.
2,052 次查看
Creative
Addition:
1) Image with lens attached (see below)
2) ar0521 - monochrome
1,622 次查看
JesterOfHw
I've run into this exact issue as well. was there a solution to this?
EDIT: I tried the patch and it solved this issue for me.
