iMX8 Gstreamer, pointer to access to overlay rectangle, GstBuffer data
Keith_RL
Using an iMX8MPLUS-BB, Yocto honister,
Gstreamer plugin that can write initially static data (RGBA)  that is overlaid on video. Similar to what is described in
Basic tutorial 8: Short-cutting the pipeline (gstreamer.freedesktop.org)
The overlay on video will be a gst_video_overlay_rectangle
Gst_video_overlay_rectangle_new_raw(
                GstBuffer * pixels,
                gint render_x, render_y
                gint render_width, render_height
GstVideoOVerlayFormatFlags flags)
In old Gstreamer 0.10 the GstBuffer structure was as follows and contained a pointer to the actual data, *data. And a Macro for access the pointer. Looks like what I need. But is old gstreamer
struct _GstBuffer {
  GstMiniObject          mini_object;
  /*< public >*/ /* with COW */
  /* pointer to data and its size */
  guint8                *data;
  guint                  size;
  /* timestamp */
  GstClockTime           timestamp;
  GstClockTime           duration;
  /* the media type of this buffer */
  GstCaps               *caps;
  /* media specific offset */
  guint64                offset;
  guint64                offset_end;
  guint8                *malloc_data;
  /* ABI Added */
  GFreeFunc              free_func;
  GstBuffer             *parent;
  /*< private >*/
  gpointer _gst_reserved[GST_PADDING - 2];
GST_BUFFER_DATA (buffer)
The iMX8 used GStreamer Core Library version 1.18.5, where the structure of GstBuffer is a follows
struct _GstBuffer {
  GstBufferPool         *pool;
  /* timestamp */
  GstClockTime           pts;
  GstClockTime           dts;
  guint64                offset;
  guint64                offset_end;
It no longer provides the data pointer and uses GstBufferPool, I have investigated the GstBufferPool but have not found an obvious method to get the memory address, so  is there a mechanism for obtaining a pointer to the memory address from the GstBufferPool ?
Keith_RL
Found the answer to my question in the gstreamer 0.10 to 1.0 porting guide
docs/random/porting-to-1.0.txt · master · GStreamer / gstreamer · GitLab
Keith_RL
