iMX7D BSDL files
iMX7D BSDL files
givcha
The package with BSDL files for iMX7D family contains only 2 devices (14x14 and 19x19), but what about the bigger ones?
For the test purposes I need a BSDL for iMX7D3EVK10SC which is BGA488 (28x28), can you please share it with me.
Labels (3)
brian14
Hi @givcha
Based on the datasheet from the iMX7D family there are only two package types 12x12 and 19x19. Your given part number is a 12x12 package type.
IMX7D3EVK10SC
Part Series = IMX7D
Part differentiator = 3 (Baseline Feature-set)
Temperature Tj = E (Extended Cons -20 to +105 C)
Package Type = VK (MAPBGA 12 x 12)
Frequency = 10 (1 GHz)
Fusing = S (Security Enabled)
Silicon Rev = C (Rev 1.2)
Tell me if you have any other part number or something that I overlooked on your question.
Have a great day!
DaveSim
Oh,this is also a imx7d bsdl question. And I'm facing another question now. My mcu type is imx7d2dvk12sd , but I can't get anyresponse signal at tdo port except one clock period low .
DaveSim
Okey,Jtag chain worded . There is a pin-config thing.
brian14
Hi @givcha
IMX7D3EVK10SC
Part Series = IMX7D
Have a great day!
givcha
@brian14 ,
thank you for pointing my nose to the fact that I missed)))! I didn't even try to look inside BSDL file for 12x12 device that I already have (thinking of balls value 12x12, not size in mm).
Thank you for help! The question is closed!
