iMX6quad Brightness Control
997件の閲覧回数
nandish_sg
Hi all.
I am trying to control the LVDS display brightness in imx6q in linux 4.9.87 kernel version.
But when i give the commands in terminal for increment and decrement it work only high(ON) and low(OFF)  of the display. i am not able to see the any changes in brightness of display.
i am stuck at finding the the root cause and can any one help me how to resolve this issue,
the files list for related to the brightness control is as given below. and find the attached driver files zip.
1) /nxp-opensource/kernel_imx/drivers/pwm/core.c
2) /nxp-opensource/kernel_imx/drivers/pwm/pwm-imx.c
3) /nxp-opensource/kernel_imx/include/linux/pwm.h
4) /nxp-opensource/kernel_imx/drivers/video/backlight.c
5) /nxp-opensource/kernel_imx/drivers/pwm/sysfs.c
6) /nxp-opensource/kernel_imx/drivers/regulator/pwm-regulator.c
7) /nxp-opensource/kernel_imx/drivers/leds/leds-pwm.c
8) /nxp-opensource/kernel_imx/drivers/video/backlight/pwm_bl.c   // MAIN DRIVER FILE
----------------------------------------------------------------------DISPLAY OFF (BLANK)-------------------------------
$ echo 0 > sys/class/backlight/backlight/brightness
BL UPDATE STATUS : 0
PWM BACKLIGHT POWER OFF
CORE PWM CONFIG
---------------------------------------------------------------------------DISPLAY ON -----------------------------------------------
$ echo 1 > sys/class/backlight/backlight/brightness
BL UPDATE STATUS : 1
INSIDE BL UPDATE STATUS FUN Brightness : 1
INSIDE DUTY CYCLE
lth Brightness :0
period : 0
Duty Cycle after compute : 0
pb->period is : 0
CORE PWM CONFIG
$ cat sys/class/backlight/backlight/brightness
1
$ cat sys/class/backlight/backlight/max_brightness
14
Best Regrads
SGN
2 返答(返信)
905件の閲覧回数
nandish_sg
Hi igor,
Thanks for your quick reply. i tried for the same but it not works for me again same result no brightness control,
Can any one help me to resolve this issue, if you need any input from me please let me know.
SGN
905件の閲覧回数
igorpadykov
Hi nandish
one can try to test with nxp L4.9.88 kernel (check for "pwm") :
imx6qdl-sabresd.dtsi\dts\boot\arm\arch - linux-imx - i.MX Linux kernel
