iMX6ULL u-boot cannot recognize kernel image
abdullahkahrama
This question is a duplicate of:
https://community.nxp.com/t5/i-MX-Processors/iMX6ULL-u-boot-cannot-recognize-kernel-image/m-p/130687...
I have a custom board that I am trying to bring up. It passes the DDR stress tester over USB HID.
I have build an image according to i.MX_Yocto_Project_User's_Guide. My build configuration was:
MACHINE=imx6ullevk
DISTRO=fslc-framebuffer
IMAGE=core-image-minimal
I have then run dd command to burn .wic file to an SD card. The board boots up with SD card, however here is what I see on the terminal:
U-Boot 2020.10+fslc+g80c23498b4 (Mar 04 2021 - 17:46:24 +0000)
CPU:   Freescale i.MX6ULL rev1.1 900 MHz (running at 396 MHz)
CPU:   Commercial temperature grade (0C to 95C) at 48C
Reset cause: POR
Model: Freescale i.MX6 UltraLiteLite 14x14 EVK Board
Board: MX6ULL 14x14 EVK
DRAM:  512 MiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... Card did not respond to voltage select!
*** Warning - No block device, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   Could not get PHY for FEC1: addr 1
Could not get PHY for FEC0: addr 2
No ethernet found.
Normal Boot
Hit any key to stop autoboot:  0
Booting from net ...
No ethernet found.
No ethernet found.
zimage: Bad magic!
Then I try to read from the SD card, I wipe the DDR areas I am going to use, copy the zImage from the SD card to RAM, and check with iminfo and I get:
Unknown image format!
=>mmc info
Device: FSL_SDHC
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode: SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
=> mmc part
Partition Map for MMC device 0  --   Partition Type: DOS
Part    Start Sector    Num Sectors     UUID            Type
  1     8192            53392           c2827fb8-01     0c Boot
  2     65536           40478           c2827fb8-02     83
=> ls mmc 0:1
    30847   imx6ull-14x14-evk.dtb
  7350040   zImage
2 file(s)
=> md 82000000
82000000: e1a00000 e1a00000 e1a00000 e1a00000    ................
82000010: e1a00000 e1a00000 e1a00000 e1a00000    ................
82000020: ea000003 016f2818 00000002 00702718    .....(o......'p.
82000030: 04030201 e10f9000 eb0104f8 e1a07001    .............p..
82000040: e1a08002 e10f2000 e3120003 1a000001    ..... ..........
82000050: e3a20017 ef123456 e10f0000 a220001a    ....V4........ .
82000060: e310001f e3c0001f e38000d3 1a000004    ................
82000070: e3800c01 e28fe00c f16ff000 e12ef30e    ..........o.....
82000080: f160206e e121f000 e16ff009 00000000    n `...!...o.....
82000090: 02000000 00000000 00000000 00000000    ................
820000a0: e1a0401f 6204433e e2844902 e1a0000f    .@..>C.b.I......
820000b0: e1500084 349f01ac 3080000f 31540000    ..P....4...0..T1
820000c0: 73844001 2300006d e28f0f5e e8901c4e    .@.sm..#^...N...
820000d0: ed90d01c e0400001 e0866010 e082a000    ......@..`......
820000e0: e5da9002 e5dae001 e189940e e5dac002    ................
820000f0: e7daa003 e189980e e1899c0a e08dd000    ................
=> mw 81000000 0 7000000
=> md 82000000
82000000: 00000000 00000000 00000000 00000000    ................
82000010: 00000000 00000000 00000000 00000000    ................
82000020: 00000000 00000000 00000000 00000000    ................
82000030: 00000000 00000000 00000000 00000000    ................
82000040: 00000000 00000000 00000000 00000000    ................
82000050: 00000000 00000000 00000000 00000000    ................
82000060: 00000000 00000000 00000000 00000000    ................
82000070: 00000000 00000000 00000000 00000000    ................
82000080: 00000000 00000000 00000000 00000000    ................
82000090: 00000000 00000000 00000000 00000000    ................
820000a0: 00000000 00000000 00000000 00000000    ................
820000b0: 00000000 00000000 00000000 00000000    ................
820000c0: 00000000 00000000 00000000 00000000    ................
820000d0: 00000000 00000000 00000000 00000000    ................
820000e0: 00000000 00000000 00000000 00000000    ................
820000f0: 00000000 00000000 00000000 00000000    ................
=> load mmc 0:1 82000000 zImage
7350040 bytes read in 347 ms (20.2 MiB/s)
=> md 82000000
82000020: ea000003 016f2818 00000000 00702718    .....(o......'p.
82000030: 04030201 e10f9000 eb0004f8 e1a07001    .............p..
82000050: e3a00017 ef123456 e10f0000 e220001a    ....V4........ .
82000070: e3800c01 e28fe00c e16ff000 e12ef30e    ..........o.....
82000080: e160006e e121f000 e16ff009 00000000    n.`...!...o.....
820000a0: e1a0400f e204433e e2844902 e1a0000f    .@..>C...I......
820000b0: e1500004 359f01ac 3080000f 31540000    ..P....5...0..T1
820000c0: 33844001 2b00006d e28f0f5e e8901c4e    .@.3m..+^...N...
820000d0: e590d01c e0400001 e0866000 e08aa000    ......@..`......
820000e0: e5da9000 e5dae001 e189940e e5dae002    ................
820000f0: e5daa003 e189980e e1899c0a e08dd000    ................
=> imi 82000000
## Checking Image at 82000000 ...
I have attached my zImage file. (I had to zip it since the forum doesn't accept a file without a type)
What could be my problem?
Labels (2)
abdullahkahrama
Seems like clue to the problem lays here:
mmcdev=1
mmcpart=1
mmcroot=/dev/mmcblk1p2 rootwait rw
I am using mmc0 in my design, however I guess I need to configure it in uboot headers.
Setting these settings manually to mmc0, I can boot now, however "iminfo" still doesn't understand zImage.
Thank you
abdullahkahrama
mmcdev=1
mmcpart=1
Thank you
JohnKlug
Senior Contributor I
My system boots, and imi also gives me unknown image format.  I am using raw nand and ubifs with a zImage.
=>printenv loadaddr
loadaddr=0x80800000
=> printenv bootcmd
bootcmd=run t_root;ubifsmount ubi0;ubifsload ${loadaddr} /boot/zImage;ubifsload ${fdt_addr} /boot/mtcap3.dtb;if test ${tee} = yes; then ubifsload ${tee_addr} /boot/uTee-6ullevk;bootm ${tee_addr} - ${fdt_addr};else bootz ${loadaddr} - ${fdt_addr};fi
=> ubifsmount ubi0
=> ubifsload ${loadaddr} /boot/zImage
Loading file '/boot/zImage' to addr 0x80800000...
Done
=> imi ${loadaddr}
## Checking Image at 80800000 ...
=> md $loadaddr 8
80800000: e1a00000 e1a00000 e1a00000 e1a00000    ................
80800010: e1a00000 e1a00000 e1a00000 e1a00000    ................
Does imi in U-Boot understand zImage?  Maybe it only understands uImage?
