iMX6ULL SECURE BOOTLOADER: No HAB Events Found! doesn't pop out, but seems to work properly!
SicScar
Hi everybody,
I'm developing a custom board, based on iMX6ULL processor. I'm trying to bring in the secure bootlader feature (NXP HABv4).
I followed the guides inside "habv4" dictory inside uboot folder of Yocto/buildroot:
1) generated PKI tree with all certificates
2) generated the fuse table
3) burned efuses with these values (just the SRK_table, not the closing device ones)
4) built uboot outside indipendently (outside of the toolchain) , enabling the Support for i.MX HAB in menuconfig (i see HAB Blocks in u-boot-dtb.imx.log)
5) created CSF file and created the u-boot-signed.imx binary and flashed into the boot media (SD card)
Now, in Uboot menu, when i run hab_status command:
i can read :
=> hab_status
Secure boot disabled
HAB Configuration: 0xf0, HAB State: 0x66
and nothing else, i don't see the phrase No HAB Events Found!
The strage fact is that if i flash a fake signed image, i can see HAB Events popping out!
example:
=> hab_status
--------- HAB Event 1 -----------------
event data:
0xdb 0x00 0x08 0x42 0x33 0x11 0xcf 0x00
STS = HAB_FAILURE (0x33)
RSN = HAB_INV_CSF (0x11)
CTX = HAB_CTX_CSF (0xCF)
ENG = HAB_ENG_ANY (0x00)
--------- HAB Event 2 -----------------
event data:
0xdb 0x00 0x14 0x42 0x33 0x0c 0xa0 0x00
0x00 0x00 0x00 0x00 0x87 0x7f 0xf4 0x00
0x00 0x00 0x00 0x20
RSN = HAB_INV_ASSERTION (0x0C)
CTX = HAB_CTX_ASSERT (0xA0)
--------- HAB Event 3 -----------------
event data:
0x00 0x00 0x00 0x00 0x87 0x7f 0xf4 0x2c
0x00 0x00 0x01 0xe8
--------- HAB Event 4 -----------------
event data:
0x00 0x00 0x00 0x00 0x87 0x7f 0xf4 0x20
0x00 0x00 0x00 0x01
--------- HAB Event 5 -----------------
event data:
0x00 0x00 0x00 0x00 0x87 0x80 0x00 0x00
0x00 0x00 0x00 0x04
But with the correct one still can't see No HAB Events Found!.  Is it okay? maybe with the newer version of cst this feature changed (i'm using cst-3.3.1)? or I'm missing something?
Thanks a lot!
Simone
Labels (3)
Yuri
SicScar
Hi Yuri, thanks for replying to me.
Yes, I'm using NXP U-boot
Thanks for the link, it doesn't seem to be my specific case but I'll try to understand if that's the way to follow.
Simone
